Hello Guest it is October 21, 2026, 08:00:24 AM
Author Topic: Limit Switch Problems  (Read 57236 times)
Re: Limit Switch Problems
« Reply #30 on: July 02, 2008, 06:24:41 AM »
Thanks Hood.  I think that will work better for me.........
Again thanks
Inivator
« Reply #31 on: July 02, 2008, 10:14:34 AM »
Hallo I have also a problem whith te swithes when i have the home the good direction then the axis go the wrong way , when i change that de then the functions on the keybord are wrong
« Last Edit: July 02, 2008, 10:31:22 AM by jd1uth »
« Reply #32 on: July 02, 2008, 02:49:18 PM »
What type machine are you running? Does the table move or the spindle?
« Reply #33 on: July 02, 2008, 03:38:09 PM »
Hello Brett
The machine is a  Zoltar    http://www.zoltar-cnc.nl/?p=classic
« Reply #34 on: July 02, 2008, 05:51:28 PM »
JD, have a look at this thread and the link in it as well. I think they will fix you up.  :) If they don't we will try our best to.
http://www.machsupport.com/forum/index.php/topic,4327.0.html
