Hello Guest it is September 24, 2026, 07:06:58 AM
Author Topic: newbee needs a little help  (Read 17172 times)
davestea
« on: May 22, 2006, 09:20:37 PM »
using M3 lathe Sherline R1.84
loaded by dealer on supplied system from TableTop.
acts the same as my demo copy -
clicking on file - import dxf does nothing at all -
what am I doing wrong?  tried all 3 main screens
ds
Re: newbee needs a little help
« Reply #1 on: May 22, 2006, 09:55:21 PM »
The DXF importer is not working because the old one was taken out... we will be building up a new one but it is going to be many months before we have it done.
Sorry about that
Brian
www.newfangledsolutions.com
www.machsupport.com
davestea
« Reply #2 on: May 22, 2006, 10:02:12 PM »
ok - so any suggestions on how I can convert a dxf to g-code so I can get it into M3?
OH! and not have to spend another fortune ---
« Reply #3 on: May 22, 2006, 11:08:42 PM »
try lazycam, it comes bundeled with mach 3, look for it on the mach3 folder, there is a video about lazycam on the tutorials section on this website
hope that would get you started
Fernando
« Reply #4 on: May 23, 2006, 08:12:15 AM »
If it is a mill you should be Good to go with LCAM but if ti is a lathe it is going to be a bit...
www.machsupport.com
