Hello Guest it is October 21, 2026, 06:29:00 AM
Author Topic: Setting up MaxNC T2  (Read 28146 times)
Re: Setting up MaxNC T2
« Reply #10 on: June 22, 2008, 11:36:10 AM »
I thought the enable2 problem may be because of the MaxNC NC Mode, but when I turn MaxNC Mode off and restart the program the enable LEDs still do not function for enable signals 2 and up. So its not the MaxNC mode but something to do with the MachTurn profile itself.
I have managed to get the axis working and the Spindle speed and Spindle reverse. The only problem I have now is I can not figure out how to get the encoder working on the spindle. When I run the spindle there is no output waveforms from the lathe controller on any of the pins 2 through 4 like I thought there would be.
Its getting close though.
Shawn
« Reply #11 on: June 22, 2008, 05:28:50 PM »
I figured out how MaxNC does the thread control. You have to send a pulse on pin3. This enables the spindle encoder's quadrature signals to be relayed out on pins 4 and 5.
I doubt this system will work with Mach3.
I am going to write my own program for the one PIC16C84 that is used for the spindle encoder to output a sync pulse that is expect is what Mach3 requires.
I will provide this code to anyone who would like it.
Shawn
« Reply #12 on: August 27, 2013, 07:29:58 PM »
did anyone figure out how to make a maxnc t2 lathe work with mach3?
