Hello Guest it is October 20, 2026, 02:54:58 PM
Author Topic: Attatch a hotkey to a mach 3 button?  (Read 21991 times)
Offline Zaae
  •  120 120
« on: June 19, 2008, 11:31:28 AM »
I've found and modified some code that I've managed to get working with the 'auto tool zero' button. That works nicely.
I'd like to have it so that the 'alt+z' key combo will trigger this function. Is there a way to do this?
Thanks!
Re: Attatch a hotkey to a mach 3 button?
« Reply #1 on: June 19, 2008, 01:47:42 PM »
If you open your screen in Screen4 you can double click on the button in question and asign a Hotkey for it. Once done it is best to save the screenset with a different name so that if you upgrade in the future it wont be overwritten.
Offline Zaae
  •  120 120
« Reply #2 on: June 19, 2008, 02:55:55 PM »
Too easy.
I'll have to try something tougher next time!
Thanks =)
« Reply #3 on: June 19, 2008, 02:57:57 PM »
Everything is easy when you know how, the problem is knowing how, but everyday I am learning more hows :D
« Reply #4 on: September 15, 2008, 03:22:56 PM »
Hood,?
when in mach 3 I want to be able to press the Z button on my keyboard and have the Z dro zero out
How do I set this up.
? Triggers and oem codes.
If so how do you set them.
Brian
« Reply #5 on: September 15, 2008, 03:44:11 PM »
Brian, I would stay away from using the z key for that as it is a native mach key in the default screen. If your doing a screen from ground up, it should be OK but be careful, lots of gotchas in modifying one. Mapping a key to zero the z axis dro is simple enough. First, copy your screen your wanting to modify and rename it something unique. Then open it in screen 4 and choose the button that zeros the dro and assign the key as its hot key. I think there is a screen 4 tutorial in the videos section.
