Hello Guest it is November 23, 2026, 01:11:39 AM
Author Topic: Labeled my Shuttle pro...  (Read 35646 times)
Offline Sage
  •  370 370
Re: Labeled my Shuttle pro...
« Reply #10 on: November 22, 2008, 11:57:07 AM »
I see you have buttons labeled STEP and REG what do you have under those buttons and what do they do for you?
Sage
« Last Edit: November 22, 2008, 11:59:47 AM by Sage »
« Reply #11 on: November 22, 2008, 05:57:59 PM »
The Step is the same as the "single block" button and the Reg is the "Regenerate" button.  :)
Offline Sage
  •  370 370
« Reply #12 on: November 22, 2008, 06:45:44 PM »
I don't see codes for those in the pull-down choices. Where did you find those?
Sage
« Reply #13 on: November 22, 2008, 06:54:48 PM »
You have to look a little closer, "step" is labeled as "singlestep" in the dropdown menu and the regen is using one of the OEM buttons which the OEM code for regen is 160.
Offline Sage
  •  370 370
« Reply #14 on: November 22, 2008, 08:01:54 PM »
Yes I saw the "single STEP" in the pull down" but you said "Single BLOCK". Single "BLOCK" is a function on the Mach screen (Alt-N) but is not in the pull down.
 So is this a typo in the setup screen?
Sage
« Last Edit: November 23, 2008, 02:25:56 PM by Sage »
« Reply #15 on: November 22, 2008, 08:10:53 PM »
I've heard it called both ways so I just never really thought about it-  :D
Offline josh
  •  101 101
« Reply #16 on: February 17, 2010, 08:11:05 PM »
what does the button FLD stand for and how does it work
Looks good Dave.   :)
« Reply #17 on: February 17, 2010, 08:56:35 PM »
I'll just venture a guess till Dave gets back to ya.
Hope ya don't mind Dave,
Russ :)
It would toggle M8 ON and Off.
« Last Edit: February 17, 2010, 08:59:25 PM by Overloaded »
« Reply #18 on: February 18, 2010, 04:02:03 AM »
Russ :)
Thanks for jumping in, my friend  ;)
That is correct, I have that set up just as Russ shows above for "flood" coolant, although mine is actually set up for a relay to drive my "flood-air" to clear chips and cool the cutter ;)
Offline josh
  •  101 101
« Reply #19 on: February 21, 2010, 03:34:37 PM »
pretty cool
