Hello Guest it is October 16, 2026, 06:21:01 AM
Author Topic: Routing Wood  (Read 221649 times)
Re: Routing Wood
« Reply #70 on: September 25, 2008, 10:34:23 AM »
Looks like excellent work, my friend.
Are you using a software to draw these up or are the pre-prepared dxfs?
  •  9,374 9,374
Re: Routing Wood
« Reply #71 on: September 25, 2008, 10:55:49 AM »
Hi Dave,
Have you started drinking Guinness now ?.
Some of the profiles have been created using the online Gear template generator at http://woodgears.ca/gear_cutting/template.html and some have been created using GearDXF from Forest Moon Productions at http://www.forestmoon.com/Software/GearDXF/. The tool radius offset function and subsequent GCode was created using CamBam at http://www.brusselsprout.org/CAMBAM/download.htm.
It's all free stuff just waiting for you to download.
Best regards.
Re: Routing Wood
« Reply #72 on: September 25, 2008, 11:22:18 AM »
 :D  ughhh, no sir, that stuff would give me rot gut for sure, just way too heavy of a beer for me.
Thanks for putting up the links, I'll have a look around over there-  :)
  •  9,374 9,374
Re: Routing Wood
« Reply #73 on: October 07, 2008, 04:38:48 AM »
While I still had a small piece of plywood left over I thought I would try this - they almost fit perfectly. (If I had a job I could be dangerous).
Re: Routing Wood
« Reply #74 on: October 07, 2008, 11:30:49 AM »
Close enough! Paint a picture on them (or route a pic!) and start selling them -  ;D
  •  9,374 9,374
Re: Routing Wood
« Reply #75 on: October 12, 2008, 11:27:51 AM »
                                                  FOR SALE
4 piece jigsaw puzzles - not too difficult - would suit adult with a mental age of 4 months.
Offers invited
        (it's a joke and no offense is intended)
Re: Routing Wood
« Reply #76 on: October 12, 2008, 12:53:15 PM »
lol, perfect  ;)
  •  9,374 9,374
Re: Routing Wood
« Reply #77 on: October 23, 2008, 05:39:53 AM »
I am back on the clock gears again but I have learn't (lesson 1) that not all plywood uses glue that is strong enough to stop de-lamination when cutting fine detail.
The escapement wheel on the right was just a test, as in practice it would be made from 5 ply not 3 ply and certainly a lot better quality plywood.
The wheel on the left was cut from 'trafolite' (I really love this stuff) but it was held to the table with low tack double sided sticky and it moved on the very last cut (oh bother I said). I tried stronger adhesion tape but the next wheel, which cut perfectly, broke whilst I was trying to prise it free from the table (oh bother, again). The second lesson learn't was that I need a selection of double sided tape with varying adhesion properties.
Thought you might like to see these pictures anyway - even though they are rubbish.
Re: Routing Wood
« Reply #78 on: October 23, 2008, 06:44:30 AM »
Neat Tweakie,
  What is the dia. of the part ?
RC 8)
Maybe plop a coin down for reference next time ? ;)
JAT
« Last Edit: October 23, 2008, 06:50:52 AM by Overloaded »
  •  9,374 9,374
Re: Routing Wood
« Reply #79 on: October 24, 2008, 01:57:14 AM »
The overall diameter of the wheel is 60mm.
Good suggestion about the coin - I will try to remember to do that.
