Hello Guest it is November 21, 2026, 08:47:54 AM
Author Topic: Mach3 Flash OEM .fla: "Mach Nation 11-20.fla"  (Read 150005 times)
Offline klmark
  •  107 107
Re: Mach3 Flash OEM .fla: "Mach Nation 11-20.fla"
« Reply #10 on: June 18, 2008, 04:27:56 PM »
Hi Guys
 I have installed the new Mach Nation screen set if I uncheck the setting in Config- Generl config ( Lock Rapid FRO to Feed FRO ) I can't adjust my Feed Rate on the front Program screen Or I am doing something wrong Let me Know
                 Thank you   klmark
Offline klmark
  •  107 107
« Reply #11 on: July 01, 2008, 04:55:11 PM »
Hi Guys
 Still waiting on an answer on how to edit a flash screen
          Thank you   klmark
« Reply #12 on: July 01, 2008, 06:49:16 PM »
First you buy the Flash compiler, for about $700. Then you learn Flash. Then you figure out how Flash is hooked to Mach.
Not as easy as using Screen4.
Offline da21
  •  87 87
    • M-Machine
« Reply #13 on: July 02, 2008, 02:23:17 AM »
follow the flash tutorial first is your best bet
http://www.machsupport.com/videos/movies/howto/flvplayer.swf
you will also require a flash compiler such as Adobe flash cs3
dave
« Reply #14 on: October 02, 2008, 03:29:32 PM »
I am getting an "unexpected file format" when I try to open the .fla in flash 8
Anyone getting the same??
Regards
Fernando
Offline lemo
  •  135 135
« Reply #15 on: November 09, 2008, 07:19:26 PM »
I am gonna "Stump" a little here for Jason: He has put, 1000's of hours into the development of Flash for Mach over the past 2.5 years.
I just got into it and I think it's mandatory that the base package from him for 30$ is being bought. Just thinking about the cool stuff which can be unleashed with FlashCS4 and Mach3 gives me goose bumps. Besides that, Jason is on the ball 24/7 as it seems. Today is Sunday and I bought the Pack1 of his really cool contents and within minutes I got a message from him personally getting me all set up with it....
Cheers to Jason and his flashy crew!!!
Cut five times and still to short...
« Reply #16 on: September 21, 2010, 05:36:53 PM »
awesome, Great Screen Set !!! Thanx for Sharing !!
