Hello Guest it is November 13, 2026, 07:53:21 PM
Author Topic: Output Pin Problem  (Read 50596 times)
Re: Output Pin Problem
« Reply #10 on: July 27, 2008, 06:15:18 PM »
Hey Dave,
I'm not having the best luck with the 2 that I have.
I will wait for Mr. Duncan to respond before making any final determinations.
Here is a problem I am having with the 2nd one.
http://www.machsupport.com/forum/index.php/topic,7679.0.html
RC
« Reply #11 on: July 27, 2008, 06:53:40 PM »
Ok, then it looks like I'm looking around some more-  ;)
Offline olf20
  •  325 325
« Reply #12 on: July 27, 2008, 08:13:56 PM »
Hi all, hope everyone is doing well!!
budman68, what other bob's are you looking at??? I'm on my third cnc4pc bob.
Thanks olf20
Mach3, Atlas Knee Mill, 4th Axis, VcarvePro, ESS, Super PID.
Been Heating with corn since 1998
« Reply #13 on: July 27, 2008, 08:15:23 PM »
OLf,
any c11's buy any chance ?
RC
Offline olf20
  •  325 325
« Reply #14 on: July 27, 2008, 08:25:21 PM »
No, two C1's and I just ordered a C1G. The first board looked like it was a proto type. No sockets for the IC's.
The second board failed while I was trying to get the Auto Z  zero working. The chips that were sent did
not match up with my board, so I still don't have a machine running. I just ordered a C1G to get the machine
running while I try and sort out the problems with the second C1.
olf20
« Reply #15 on: July 28, 2008, 11:05:38 AM »
Olf, I'm really not sure what to use now but Hood speaks highly of the PMDX 122 and I've also heard many good things about the Boards from Bob Campell. These seem a little overkill for what I want as I was hoping to get away with a lower price as I'm not hooking up any motor drivers to the board that I'd be getting, I just want more I/O s for relays and other gadgets  :)
« Reply #16 on: July 28, 2008, 12:25:47 PM »
 Have a look at the PoKey, just got one a few days ago and so far its looking good :) Its nt a breakout but will be very handy for lots of extra I/O
 It is a USB device that can be used to connect 55 digital Inputs or Outputs, five of which can be analogue, at the moment though Art doesnt have the analogue done in the plugin but if there is enough interest he will do it.
 I have been messing around with it for the last few days, had a 12 position rotary switch hooked to it and made a small Brain up so I can set the FRO from 1% to 150% in 12 stages, it works great. If the Analogue part of the plugin is done a Pot could be used instead to give infinite FRO and only use up one of the Inputs. Each pin can be set up as either an Input, an Output or even a keystroke.
« Reply #17 on: July 28, 2008, 12:31:31 PM »
Meant to give a link and also mention that until 10th Aug Mach users get a 15% discount and free shipping. I have no affiliation at all with the product, just saw mention of it on the Yahoo group and decided to give it a try for a pendant I am making for the new mill.
www.poscope.com
and the Discount CODE: MACHCNC16
« Reply #18 on: July 28, 2008, 12:47:39 PM »
Hey now, that's very interesting. It was a bit more than I'd hoped but jeez, look at all those I/O's!!!  :D
Thanks as always!
« Reply #19 on: July 28, 2008, 01:03:34 PM »
You would have to check up to see if there is enough power for relays, not really read the manual so not quite sure, I just saw it as an excellent board for connecting up external switches etc
