Hello Guest it is November 17, 2026, 02:10:31 AM
Author Topic: Output Pin Problem  (Read 50635 times)
Re: Output Pin Problem
« Reply #20 on: July 28, 2008, 01:06:26 PM »
Indeed, I'm reading up on it now (pdf manual online). Thanks for the heads up-
Offline Vogavt
  •  260 260
« Reply #21 on: July 28, 2008, 07:48:09 PM »
Have you tried a different cable?
No, but I will.
Checked the cable out with a continuity check. Each pin checks okay.
Checked the port on the board as well. Checks out okay from pin-holes to the soldered points on the board.
Tried moving the cable and the RS-232 on the board. Everything is rock solid.
Still can't get pin 1 to light up, nor 16.
« Last Edit: July 29, 2008, 10:54:22 PM by Vogavt »
