Hello
Guest
it is
October 21, 2026, 10:20:23 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Welding - On / Off
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Welding - On / Off (Read 12189 times)
Marchantdice
1
Welding - On / Off
on:
May 29, 2008, 09:10:21 AM »
I'm looking to manufacture a welding machine (spot welding), is there a function in Mach to triger the on / off function?
Many thanks, Regards / Kevin
www.worldofcnc.com
Carnoustie, Scotland
Re: Welding - On / Off
Reply #1 on:
May 29, 2008, 09:45:16 AM »
You could use the Coolant relay signal, that way M8 would switch it on, M9 off. If you didnt want to use M8/M9 you could write a custom macro and call that from the code.
Print
Pages:
1
Go Up
« previous
next »
