Hello Guest it is October 20, 2026, 08:29:43 PM
Author Topic: Bi-directional Jogging  (Read 12645 times)
« on: May 29, 2008, 07:59:25 AM »
My x and Z axis only turns clockwise and my Y axis does not jog at all.  Any suggestions?
Re: Bi-directional Jogging
« Reply #1 on: May 29, 2008, 09:51:16 AM »
Sounds like you have your pins asigned incorrectly, or could be your parallel port cable is bad. Please attach your xml, you will need to rename it to post to the forum, suggest you rename it to P_Sheres.xml
« Reply #2 on: June 03, 2008, 03:17:29 PM »
I ran into that also , mine was the pin asignments
