Hello
Guest
it is
October 20, 2026, 03:04:56 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Should I scrap Vista for XP?
« previous
next »
Print
Pages:
1
2
3
4
5
6
Go Down
Author
Topic: Should I scrap Vista for XP? (Read 84833 times)
CT
40
Re: Should I scrap Vista for XP?
Reply #20 on:
May 29, 2008, 05:07:28 PM »
Does that computer need to be online? or can I save it to say, the USB key?
I did the driver test and it is saying that mach3 "took control"
There was a good line and the freq. is approx. 25,800.
It all seemed ok. Colin
Last Edit: May 29, 2008, 05:09:40 PM by CT
Logged
Carnoustie, Scotland
Reply #21 on:
May 29, 2008, 05:11:57 PM »
Yes saving to USB is fine.
Looks like your pulse engine is fine then.
Logged
M250cnc
591
Reply #22 on:
May 29, 2008, 05:23:44 PM »
A message for Jeff Birt
The fact of the matter is the best time to get a new OS is when like XP it is near the end of it's life all the bugs "Well Most Of Them" have been ironed out as with XP and SP3 this link shows that Vista takes more than twice as long to complete a task
http://news.cnet.com/Windows-XP-outshines-Vista-in-benchmarking-test/2100-1016_3-6220201.html
The best OS for Mach would the one that uses the least resources and it ain't Vista
I remember at the time when XP first came out someone from Redmond said XP had fixed 20,000 bugs someone else said but they have created 30,000 new ones
Phil_H
Logged
CT
40
Reply #23 on:
May 29, 2008, 05:41:04 PM »
For some reason I am having trouble replying with this attachment. I guess I need assistance with that too.
Logged
Kristin D
203
Take that you LazyCam, next stop the glue factory!
Reply #24 on:
May 29, 2008, 05:43:16 PM »
Colin,
When your reply, look for the additional Options button, it will let you add a file.
Kristin
Logged
M250cnc
591
Reply #25 on:
May 29, 2008, 05:50:37 PM »
Hi CT i think you may have to rename it too. I think i am right in saying you cannot upload any file using a default name IE "Mill.xml"
So the copy on the USB drive rename to a non standard name ie "colins.xml" and then try
You will get there in the end.
Phil_H
Logged
CT
40
Reply #26 on:
May 29, 2008, 06:04:03 PM »
It is telling me that my upload folder is full?? Not sure what to do here or even if it went through!
Logged
CT
40
Reply #27 on:
May 29, 2008, 06:06:30 PM »
I am trying send the entire folder?...or am I sending one of the files in it?
Logged
Reply #28 on:
May 29, 2008, 06:06:55 PM »
sent you an email.
Logged
CT
40
Reply #29 on:
May 29, 2008, 06:36:59 PM »
It took me forever, but I think I finally got it off to him
I am not an expert to start with and Vista is still new as well....I'm a DoughHead should sum it up! Thanks to all for your patience. Colin
Logged
Print
Pages:
1
2
3
4
5
6
Go Up
« previous
next »
