Hello Guest it is November 01, 2026, 11:53:21 AM
Author Topic: Solidedge2d to Lazycam text spacing problem.  (Read 42159 times)
Re: Solidedge2d to Lazycam text spacing problem.
« Reply #20 on: May 30, 2008, 10:22:48 AM »
Hi....
I have the option " Explode " in A9CAD, and have tryed to explode the text-string, then save as dxf. file
and load it in Lazycam, still spacing and size problem.....
See for your self...
Regards John Hansen
« Reply #21 on: May 30, 2008, 11:53:47 AM »
I see, and I wish I could be of more help to you but I'd seriously give that program a try since it seems to work perfectly for me.  8)
« Reply #22 on: May 30, 2008, 11:59:13 AM »
See if this dxf or LazyCam file work for you-
« Reply #23 on: May 30, 2008, 02:40:42 PM »
Hi
Ok now i have tryed non fixed and fixed, and fixed looks fine in my lazycam...
I have installed Progecad smart via oyur link... i also tryed to explode the file, but with no luck...
Can you discribe what you precise what you do... E.g. do you mark the hole panel and then explore or???????
Regards John Hansen
« Reply #24 on: May 30, 2008, 03:06:32 PM »
Sure,
These are the steps I do:
Open the program, click file-open and browse for the file. Open the file and "lasso" the whole drawing around the outer rectangle then click the left mouse button which makes all the lines in the image, dotted. Then I go to the top menu to "Express-Text-Explode Text". When you click that, you'll notice that all the block text is now turning into outlined text, right before your eyes, word by word. When it's all done, I click "File-Save as" and a dialog box comes up and under "save as type", I save it as Autocad release 11/12 ASCII (dxf).
That should open up perfectly in your lazycam as I posted for you earlier today. Let us know how it works out-
« Reply #25 on: May 30, 2008, 03:30:44 PM »
Hi
IT WORKS !!!!!!!!!!!!!!!!!!!, how can i thank you.....
Well now that we have confirmed that it is possible to overcome that problem, i am ready to purchase Mach3...
Thanks for your help, sorry it has taken some time for me to understand....
But happy i am now....
Best regards John Hansen, Denmark
« Reply #26 on: May 30, 2008, 09:15:02 PM »
John, glad to be of help, and again, never be sorry about that as now you can help somebody else someday-  8)
« Reply #27 on: June 10, 2008, 06:13:02 AM »
what arecomponent of lazycam? how to using lazy cam? do you have document about lazycam? please send to me to thuc_bk69@yahoo.com
thank you very much
