Hello Guest it is November 01, 2026, 10:13:23 AM
Author Topic: Solidedge2d to Lazycam text spacing problem.  (Read 42142 times)
Re: Solidedge2d to Lazycam text spacing problem.
« Reply #10 on: May 28, 2008, 02:06:03 PM »
Hi again...
what is the explode function doing??? Should i havea similar function in SoligEdge, and does it have a diff. name for the function ( Explode )
Rgd John hansen
« Reply #11 on: May 28, 2008, 03:15:43 PM »
Great question, and unfortunately I can't give you an answer as I wouldn't know the actual process that is happening when doing that. I believe there's a forum for solidedge, possibly inquire there?
« Reply #12 on: May 28, 2008, 11:08:32 PM »
Ok Thanks...
Rgd John Hansen
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #13 on: May 29, 2008, 02:08:53 AM »
Hi, John
Exploded the text also, dxf below, Exploding the Text turns it into small line segments & arcs in most cad's..
Pocket & Offsetting in LCam Pro or CAD/CAM programs.
Chip
« Reply #14 on: May 29, 2008, 10:15:40 AM »
Interesting, Chip, I wonder why the outer circle doesn't show up in your DXF?
John, do you see the outer circle in Chips DXF?
« Last Edit: May 29, 2008, 10:18:02 AM by budman68 »
Offline Chip
  •  2,055 2,055
« Reply #15 on: May 29, 2008, 03:27:14 PM »
Hi, Dave
Your rite it missed it, DXF transfers are Flaky at best.
Chip
« Reply #16 on: May 29, 2008, 04:13:20 PM »
Ah, ok, and your statement is VERY true!  :)
« Reply #17 on: May 30, 2008, 04:03:24 AM »
Hi
What is that Progcad, or is it Progecad???
I have found out that if i use " i " the followering letter spaces against the " i "...
e.g    "acti ve" or "hi v" ....  I have no broblem with showing my panel in dxf viewer, Solidedge2d, A9CAD, and
others freeware and trail cad programs.
I have also tryed loading panel dxf file in A9CAD and used Explode function, then saved and open in Lazycam,
and with same resault..... :-[
I am not sure what you have done with my dxf. file to get it right....
I have also tryed to use 30 days Trail SE_CAD_Converter ( fore Solidedge dft. drawings ) but nothing works.
 :-[ :-[ :-[  HELP!!!!! It is the only hurtle i need to get solved......
Regards John Hansen
« Reply #18 on: May 30, 2008, 04:08:33 AM »
Hi again...
How do i take a screenshot of teh Lazycam picture???
Then i will post it, because it is not only spacing problem, it is also
size.....
Rgd john Hansen
« Reply #19 on: May 30, 2008, 10:01:17 AM »
I used autocad alot to draw but since working with dxf's all the time now, it's tempermental as hell and I can't stand it anymore. You can download "progeCAD 2008 Smart!" here:
http://www.progecad.com/compra/index.asp?left=prodotti/eng_progecad2008smart&abspage=1&lang=eng
As for taking a screenshot, if you're using windows, while you have the lazycam screen showing, just hit the print screen on your keyboard, then open up MS Paint and paste into there. Then save it as a jpg file and upload it here . (click on the additional options button to show the upload features when you reply)-  :)
