Hello Guest it is November 13, 2026, 07:57:43 PM
Author Topic: quick plasma question  (Read 13674 times)
Offline atanq
  •  19 19
« on: May 23, 2008, 02:39:33 PM »
I have mach3 on xp, which method is best to drive an external relay to switch the plasma on/off?  Is it in ports & pins> output signals> digial trig?
aaron.
Re: quick plasma question
« Reply #1 on: May 23, 2008, 02:58:02 PM »
Probably best to use the spindle relay output, that way you can start with M3 and stop with M5
Offline atanq
  •  19 19
« Reply #2 on: May 23, 2008, 04:07:56 PM »
Thanks for the reply, Hood,
I'll give that a try - it seems to work quite happily in the MDI.  Will I be able to select this option for instance when importing a file from LazyCAM into Mach3?
Aaron.
« Reply #3 on: May 23, 2008, 04:52:07 PM »
Dont use LazyCAM but I am sure it will call M3 for spindle Start and M5 for stop when you generate the code.
