Hello Guest it is October 21, 2026, 02:02:19 AM
Author Topic: mach3 crashes  (Read 24312 times)
Offline drew
  •  79 79
mach3 crashes
« on: May 12, 2008, 12:35:07 PM »
After using the turn wizard, posting code, then exiting back to Mach I get an artcode error 709 repetely and watch dog error till mach crashes and closes .
Drew
If I had something important to say it would be here.
Re: mach3 crashes
« Reply #1 on: May 12, 2008, 02:44:08 PM »
I try not to use the Wizards in Mach3. I think they pretty much offer a disclaimer of non-authorization. Your problem is probably starting and ending there. Try to find a program or ad-on that performs the duty you want and you should get better results!
Good Luck!!!
Offline DAlgie
  •  314 314
    • Algie Composite Aircraft
Re: mach3 crashes
« Reply #2 on: May 12, 2008, 03:40:42 PM »
The turn wizards work great for me, always have, and I've never had an error with them. I'm using turn 1.84 FWIW, which seems to be the last real updated version of turn there is.
   DaveA.
Re: mach3 crashes
« Reply #3 on: May 12, 2008, 06:23:13 PM »
Dont use the wizards much but on the occasions I have done they work fine.
 What computer do you have? can you try turning off the toolpath to see if it helps.
« Last Edit: May 12, 2008, 07:01:30 PM by Hood »
Re: mach3 crashes
« Reply #4 on: May 12, 2008, 06:48:14 PM »
I have been using the turn wizards and the thread mill wizard daily with no problems
Offline drew
  •  79 79
Re: mach3 crashes
« Reply #5 on: May 13, 2008, 11:33:53 AM »
It seems its not the wizard but the second time I try to load any g-code mach spews out artcode 709 errors till mach self terminates.
Thanks Drew
Offline fast89
  •  165 165
Re: mach3 crashes
« Reply #6 on: September 29, 2015, 07:11:43 PM »
so what does artcode 709 mean? is there a list of artcodes? i'm getting this error when loading gcode files. The files are good, nothing but some tool changes for testing.
Re: mach3 crashes
« Reply #7 on: September 29, 2015, 08:02:01 PM »
ArtSoft no longer supports Mach 3 and has their hands full trying to get Mach 4 to work which doesn't look promising. Good luck trying to get a response for a Mach 3 error code.
Re: mach3 crashes
« Reply #8 on: September 29, 2015, 09:04:05 PM »
Try turning off Watchdog's in General Config.
Offline Davek0974
  •  2,606 2,606
Re: mach3 crashes
« Reply #9 on: September 30, 2015, 04:47:06 AM »
Why would any supplier stop supporting a working system until the new version is fully 100% up and running and mostly de-bugged??
Makes no sense, i'm not denying it, just saying...
