Hello Guest it is November 13, 2026, 09:39:47 AM
Author Topic: Potentiometer Input  (Read 14890 times)
Offline SimonD
  •  143 143
Potentiometer Input
« on: May 10, 2008, 03:05:43 PM »
Guys,
Is there a way to get a potentiometer input into Mach3 without using a PLC or ModIO?
I have a feedrate pot on the control panel of my lathe which I would like to connect up if possible however using a PLC or ModIO just for feerate override seems a bit over the top! i have enough other inputs/outputs already using a smoothstepper.
Is there a simple add-on card I can buy?
Simon
Re: Potentiometer Input
« Reply #1 on: May 10, 2008, 03:45:48 PM »
Hi, If you picked up a usb fighter pilot type joystick most have at least 2 potentiometers as an x,y axis, you could then use keygrabber to interface to Mach. You will probably have to change the type of potentiometer the joystick uses as the one I got had slider types but as long as the resistance is the same you'll be ok.
Hope this helps.
John
Offline SimonD
  •  143 143
« Reply #2 on: May 10, 2008, 04:30:17 PM »
John,
Thanks for the reply. I already have the potentiometer, I just need to hook it into Mach3 somehow. How does a keygrabber read a potentiometer?
Simon
« Reply #3 on: May 10, 2008, 04:44:27 PM »
Hi, Have read of the Customising Mach .pdf section 8.1.1 and HID controllers and futher down a section on joysticks.
Very informative and helped me out with the same problem.
John
Offline SimonD
  •  143 143
« Reply #4 on: May 10, 2008, 05:59:49 PM »
John,
Thanks for the pointer, I hadn't, I will have a read. I saw it was for Mach2 and didn't download it.
Simon
