Hello Guest it is October 30, 2026, 01:29:01 PM
Author Topic: Hitachi seiki VK-55 retrofit advice?  (Read 12288 times)
« on: May 05, 2008, 11:36:23 AM »
Hello,
I just purchased a basket case VMC.
It needs alot of work and I am looking at 10K just to get the controls going agian.
This would be the 1997 seicos control, and who knows when it will be smoked again.
Would it be a good idea to try and retrofit something like this with mach 3?
The only thing I can see causing a problem would be controling the spindle drive, it looks like the OEM control uses a digital bus for all the drives.
Here is a link to it on ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=280214611136&ssPageName=STRK:MEDW:IT&ih=018
Let me know thanks.
Re: Hitachi seiki VK-55 retrofit advice?
« Reply #1 on: May 05, 2008, 12:06:46 PM »
Hmmmmmmmm, lots of questions to ask. You need to find out what type control signal the drives will take. Are they not analog? I doubt they are step and direction.
« Reply #2 on: May 05, 2008, 12:11:35 PM »
Jus figured out that it uses yaskawa drives, that is a good thing because I think it might use -+ 0-10 V
I should be able to make Mach3 control that.
Let me know what you guys think
« Last Edit: May 05, 2008, 01:58:45 PM by wyo123 »
