Hello Guest it is November 18, 2026, 09:33:33 AM
Author Topic: Mach3 Steps per unit calculations.  (Read 20187 times)
« on: May 16, 2006, 08:27:25 PM »
Hi.  I was looking for a project to get my feet wet in php scripting and html forms, and rather than do something pointless, I made an online "steps per unit" calculator for Screw drives (ballscrews, all-thread, etc..) and one for belt drives too.
I know it's not rocket science, but someone may find it useful?
Anyway, if you're curious go here
www.mr-bean.co.uk
Please bare in mind I've only been learning php for 2 days.
Cheers,
MrBean.
« Last Edit: May 16, 2006, 08:30:21 PM by mrbean »
Re: Mach3 Steps per unit calculations.
« Reply #1 on: May 16, 2006, 09:57:11 PM »
I could be wrong, but I looks like you are dividing the microstep instead of multiplying.
I did 200 Step Per Rev, 20 TPI, and 8 as the Microstep and it came to 80, shouldn't it be 32000? 200x20x8??
ynneb
« Reply #2 on: May 16, 2006, 10:30:46 PM »
Good job Beano, Yeh Ive descided to pull my finegr out and learn C#
The thought is depressing that it may take me many years b4 I can do any thing like a CAM program.
But if I look back after 5 years and wish that I had started now, that thought would be even more depressing.
Keep it up with your learning.
« Reply #3 on: May 17, 2006, 04:51:06 AM »
Hi.  Thanks for trying it out.
The reason you didn't get the figures you were expecting is because you entered (TPI) instead of (pitch)
A 20 tpi screw, has a pitch of 0.05 Inches.
I guess it would be useful to be able to select if you wanted to input "pitch or tpi".  I'll look into adding the choice.
@Benny
I really fancied a go at C# too.  I don't know quite what it is that I don't get about it, but there's something?
Microsofts "Visual" Development enviroment, doesn't do anything for me.  The code seems all dis-jointed.
Also I find it hard to fully grasp the OOP concept. Objects, Classes, methods etc...  It seems like a multidimentional array with bells on, and then some?
Maybe it's just me getting older and the grey matter isn't as absorbant as it used to be, or perhaps I just havn't given it enough effort.  Maybe I'll go back to it.
I hope you find it easier to pick up than I did.
Cheers,
MrBean.
« Reply #4 on: May 17, 2006, 09:48:37 AM »
Ah, My bad, didn't read it correctly..  :P
