Hello Guest it is November 13, 2026, 12:02:48 PM
Author Topic: mach3 addons  (Read 21822 times)
mach3 addons
« on: May 02, 2008, 09:17:26 PM »
I am new to the mach3 and just added the licences for the addons.butt it will not let me change the numbers for anything to make the gcode for the part.anyone got any help on this?
Calvin Nichols
Re: mach3 addons
« Reply #1 on: May 02, 2008, 09:38:11 PM »
(Mach3 Addons for Mill requires a licensed copy of Mach3 Release 1.0 or later.)
Do you have the Mach license ?  If so, are they BOTH in your Mach3 folder ?
Re: mach3 addons
« Reply #2 on: May 02, 2008, 09:51:44 PM »
yes I have both and added the in the mach3 folder.everything seems to work butt the addons and the mach3 wizard
Calvin Nichols
Re: mach3 addons
« Reply #3 on: May 03, 2008, 02:26:20 AM »
When you say it wont let you change the numbers what exactly are you meaning? If you click on a DRO and then type does the number apear?
Re: mach3 addons
« Reply #4 on: May 03, 2008, 05:45:16 AM »
the number apears when you go to the next DRO  the number is not saved in the first DRO it will defalt back to what it was
Calvin Nichols
Re: mach3 addons
« Reply #5 on: May 03, 2008, 06:20:10 AM »
You have to hit ENTER after every change that you make.
Re: mach3 addons
« Reply #6 on: May 03, 2008, 08:08:34 AM »
Thanks I have the addons working.I was clicking the save changes every time not enter...works much better.
now on the mach3 load wizard (not addons) I click on the text engraving and make the changes and looks good..butt how do you get it to post the gcode into the mach3 so you can run it?
Calvin Nichols
Re: mach3 addons
« Reply #7 on: May 03, 2008, 08:25:01 AM »
Hi Calvin,
After you pick your font, click on "Write".
RC
Re: mach3 addons
« Reply #8 on: May 03, 2008, 08:59:07 AM »
That work thanks That was so easy makes me feel stupid :P I have been wright in cad 14 butt have not tried to add it to mach3 yet. I am don't to happy with cad 14 there is a lot to it...Thanks for your help check my web site out and you can see what I am trying to do with this mill thanks  ;D
nicholscustomknives.com
Calvin Nichols
Re: mach3 addons
« Reply #9 on: May 03, 2008, 09:06:34 AM »
You should NEVER feel stupid for asking questions....NOT asking is what's really stupid.
We're all in this together. Glad I could help out.
Good Luck to you Calvin,
RC
