Mach Discussion => General Mach Discussion => Topic started by: cnichols33 on May 02, 2008, 10:17:26 PM
I am new to the mach3 and just added the licences for the addons.butt it will not let me change the numbers for anything to make the gcode for the part.anyone got any help on this?
(Mach3 Addons for Mill requires a licensed copy of Mach3 Release 1.0 or later.)
Do you have the Mach license ? If so, are they BOTH in your Mach3 folder ?
yes I have both and added the in the mach3 folder.everything seems to work butt the addons and the mach3 wizard
When you say it wont let you change the numbers what exactly are you meaning? If you click on a DRO and then type does the number apear?
the number apears when you go to the next DRO the number is not saved in the first DRO it will defalt back to what it was
You have to hit ENTER after every change that you make.
Thanks I have the addons working.I was clicking the save changes every time not enter...works much better.
now on the mach3 load wizard (not addons) I click on the text engraving and make the changes and looks good..butt how do you get it to post the gcode into the mach3 so you can run it?
Hi Calvin,
After you pick your font, click on "Write".
RC
That work thanks That was so easy makes me feel stupid :P I have been wright in cad 14 butt have not tried to add it to mach3 yet. I am don't to happy with cad 14 there is a lot to it...Thanks for your help check my web site out and you can see what I am trying to do with this mill thanks ;D
nicholscustomknives.com
You should NEVER feel stupid for asking questions....NOT asking is what's really stupid.
We're all in this together. Glad I could help out.
Good Luck to you Calvin,
RC
