Hello
Guest
it is
November 26, 2026, 12:41:44 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach Screens
LED overlay possible?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: LED overlay possible? (Read 37266 times)
on:
May 15, 2006, 04:32:16 PM »
I have adapted the Touch Screen by zealouse and used Benny's DRO skinĀ to suit my needs, hope its OK with you guys?
I was wanting to have text on some of theĀ LED's rather than at the side. I was hoping to make a skin up so that when active the text would show but it seems like LEDs cant be skinned. Is there any way to do this? An example of the LED I would like to do is the Constant Velocity LED, my screen can be seen here
http://mysite.wanadoo-members.co.uk/hoodsmachiningpages/Mach3screen.jpg
and I would rather have the text on the LED rather than at the side.
Logged
ynneb
Re: LED overlay possible?
Reply #1 on:
May 15, 2006, 05:06:20 PM »
You will have to check out the way led skin are made in the tutorial I posted.
The process is not as sraight forward as you would expect. Follow the tut closely and it will work for you.
Last Edit: May 15, 2006, 05:47:29 PM by ynneb
Logged
Reply #2 on:
May 15, 2006, 05:15:44 PM »
Thanks Benny, I already have it downloaded but forgot all about it, will go have a look now.
Logged
Reply #3 on:
May 15, 2006, 05:53:24 PM »
Benny I cant seem to add it to the screen. When I try to add it with the LED control in Screen 4 I dont have the option of using an image rather than the standard LED. When I add it as a button it shows on the screen as both on/off states.
Where am I going wrong?
Logged
Reply #4 on:
May 15, 2006, 06:17:32 PM »
I found my problem, had an older version of Screen 4, just downloaded the latest and all is working perfectly
now I just have to match up the colours to the original LEDs and all will be good.
THANKS!!! Benny for your help.
Logged
Reply #5 on:
May 16, 2006, 12:17:10 PM »
Benny
was wondering where the LEDs that are used by the latest Mach 3 version are stored as I cant seem to find them in the Bitmap folder. I want to grab one to get the colour of the ones I create identical.
Logged
ynneb
Reply #6 on:
May 16, 2006, 04:42:49 PM »
Those LEDs are stored within the mach program itself. You cant access them. Sorry
Logged
Reply #7 on:
May 16, 2006, 04:50:40 PM »
OK thanks anyway.
Logged
Print
Pages:
1
Go Up
« previous
next »
