Hello Guest it is November 22, 2026, 07:42:49 AM
Author Topic: Mach shown G code only HALF in the screen  (Read 25694 times)
« on: April 21, 2008, 06:12:49 AM »
Dear all,,
New user here.Starting build my own CNC month ago. I m using Mach 3 ( free untimed trial version)
I have try to load G Code from ARTCAM (G code file type=Mach2 mm,Gcode mm). but in Mach shown only HALF in the screen.(maybe can say RUNNING half)   Is there setting problem? Anyone know how to solve this?
Pls help me!!
Sorry about my English. Hope you all will understanding what i m try to tell.
Best Regards,
Hawk (ARTCAM designer)
Re: Mach shown G code only HALF in the screen
« Reply #1 on: April 21, 2008, 06:46:23 AM »
Unlicensed version of Mach is limited to 500 lines of code so if you load a file with over 500 lines it will only show the first 500 in the toolpath.
« Reply #2 on: April 21, 2008, 07:00:49 AM »
Hi Hood,
Ic.. Thats means Mach have not problem to load the G Code from Artcam?  I  m worry about this actually..
Where i can know more info about machine setup with Mach?
Thanks!
Best Regards,
Hawk
« Reply #3 on: April 21, 2008, 07:13:43 AM »
Please attach your code here and I will see if it has a problem. To attach the code use the full reply instead of the quick reply. You will then see an button that says additional options. You can then use that to browse to your file and it will be attached to your reply.
 What kind of info are you looking for with regards to machine setup? There are manuals and videos available from the tutorials tab at the top of the screen.
« Reply #4 on: April 21, 2008, 07:36:26 AM »
Attached. 2 type of the G code.
Actually i have purchase the 3 axis kit from Probotix.Waiting for the goods now. I have no idea how to setting with Mach. Isit just plug n play?
Regarding my quetions is. Shall we "tell' the Mach the size of the leadsrew,n etc....n how to let Mach know about the machine size? Maybe all this is Stupig quetions....:)
Best Regards,
Hawk
« Reply #5 on: April 21, 2008, 08:02:59 AM »
Its all in the manual and also in the videos. The manual is a very good source of info although reading it when new to CNC may be hard going but its definitely worth downloading it and reading through it. The videos give a quicker idea of how to set things up but dont go into as much depth.
 I have loaded your code and it loads fine see screenshot below
« Reply #6 on: April 21, 2008, 08:12:25 AM »
Thanks You very much!!!!
Hawk
« Reply #7 on: April 21, 2008, 08:17:03 AM »
Once you get your hardware if you still have p[roblems come back and I am sure we can get you up and running correctly.
« Reply #8 on: April 21, 2008, 08:40:16 AM »
thanks in advance.
Hawk
« Reply #9 on: August 02, 2008, 04:03:11 AM »
Hi Hood,
I already purchased the Mach licensed version by today. Am i receive the code or licensed file soon?
Best Regards,
Hawk
