Hello Guest it is November 24, 2026, 08:14:51 PM
Author Topic: reverse run  (Read 21946 times)
reverse run
« on: April 14, 2008, 05:23:51 PM »
When I hit "Feed Hold" and then hit "Reverse run", my head goes in a totally different direction (sometimes off the beaten path!)
Any help?
Offline Tarak
  •  229 229
Re: reverse run
« Reply #1 on: April 25, 2008, 01:04:09 AM »
Hi tclark, I have the exact same problem on every Mach machine I've built (5 to date).
I gave up trying to use reverse run a while ago.
Darc
Re: reverse run
« Reply #2 on: April 25, 2008, 07:56:55 AM »
Thanks for the feed back.  Thats a shame.  I wish it worked.  At least it's not just ME being stupid!!
Wish it was though because I need that feature.
Re: reverse run
« Reply #3 on: February 12, 2010, 02:22:11 PM »
i have this problem too
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: reverse run
« Reply #4 on: February 13, 2010, 10:00:00 AM »
After the Feed hold issue a Stop command and it should work fine
Re: reverse run
« Reply #5 on: May 11, 2010, 03:32:01 AM »
hi Guys
recently i use plasma and I very much need use reverse run. i read much post in net, and
I reached the conclusion that : "reverse run dont work very well"
Beforehand, I apologize for judging If incorrect.
If we use run reverse, we will not be lost step  ???
thx
amir
« Last Edit: May 11, 2010, 03:33:58 AM by manmardam »
**Even a clock that does not work is right twice a day**
Re: reverse run
« Reply #6 on: May 12, 2010, 10:14:31 AM »
no body ?
Re: reverse run
« Reply #7 on: May 13, 2010, 02:02:25 AM »
Why none of the Moderators do not respond?
This is an important.
My idea for "PAUSE".
When the pause button is pressed, for example the middle of a line, continue program to end line ,then act Pause button .
This idea is not lost no step.
Whether it is feasible ?
Re: reverse run
« Reply #8 on: May 13, 2010, 02:28:58 AM »
As said when you sent me a private message, Reverse Run does not work in Demo mode.
Re: reverse run
« Reply #9 on: May 13, 2010, 02:33:22 AM »
yes Hood.
but :
http://www.cnczone.com/forums/showthread.php?t=103133
this is a problem almost for all
amir
