Hello Guest it is November 23, 2026, 09:07:34 PM
Author Topic: Calibration???  (Read 12036 times)
Calibration???
« on: April 13, 2008, 04:07:38 PM »
Puzzled  ??? i made 2 1 inch squares and 2 1 inch circles I pocketed 1 square and one circle  it came out at .9998  and when i do the profile outside its bigger than 1 inch and I'm using a .125endmill with vcarve pro.... any suggestions as to why its perfect one one and real crappy on the other...
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Calibration???
« Reply #1 on: April 13, 2008, 06:01:10 PM »
Hi, Biotech1
So what's the, "real crappy on the other..." values.
Not to much info in your post to work with, Is it Backlash, Flex.
Thanks, Chip
Offline DAlgie
  •  314 314
    • Algie Composite Aircraft
Re: Calibration???
« Reply #2 on: April 13, 2008, 07:12:09 PM »
Mill bit is too small, it's walking around one way on the inside cut and the other way on the outside cut. Use as big a mill as possible when you can.
