Hello Guest it is October 25, 2026, 02:59:04 AM
Author Topic: hubbard relay board troubles  (Read 11246 times)
« on: April 12, 2008, 03:30:33 PM »
I have several hubbard relay boards and I can not seem to get them working at all.
I set it up for pin 16 and pin 17 and then set up the outputs 1 and 2 for pin 16 and pin 17.
Set the spindle relay on for output 1 and the flood for on for output 2
I have tried all 3 boards so there seem to not be a board problem.
HELP?
Thanks in advanced
Curtis
Re: hubbard relay board troubles
« Reply #1 on: April 19, 2008, 07:18:04 PM »
Did you check to see if the there is output on the pin when active with a volt meter?
