Hello Guest it is October 20, 2026, 06:02:18 PM
Author Topic: wierd behavior  (Read 12847 times)
wierd behavior
« on: April 11, 2008, 10:51:49 PM »
I was running a program when the machine started a x axis move before reaching the correct y axis point.  I checked the program which is correct.  There were also no missed steps.  I don't know what caused this.  Is there anything that could make mach not complete a line before moving to the next?  I have turned off the screen saver.  Should I also turn off the 'auto off' function for the monitor?
Any ideas would be appreciated.
Bill
Re: wierd behavior
« Reply #1 on: April 12, 2008, 02:51:11 AM »
Please attach your xml, I had this happen a while back and when I compared a saved xml and the present one there was a difference. I cant remember what it was but maybe if I see your xml it will jog my memory.
Re: wierd behavior
« Reply #2 on: April 13, 2008, 04:20:46 AM »
What you describe here. is similar to what Spinnetti  has posted on another topic on this forum (Code wanders off)
In my case setting the "look ahead" to 1 seemed to help
Jan
