Hello Guest it is October 24, 2026, 04:21:08 PM
Author Topic: Reverse Run doesn't work...  (Read 44109 times)
« on: April 11, 2008, 01:53:53 PM »
I'm using mach3 3.039 demo version on my Flame-cut cnc machine, so if i lost the cut i need to run the program in reverse and reverse run doesn't work at all ...
any suggestions ?
Thanx
Arush
Re: Reverse Run doesn't work...
« Reply #1 on: August 29, 2008, 02:38:27 AM »
  I have the same problem,reverse run led do not work.
« Reply #2 on: August 29, 2008, 03:34:09 AM »
Reverse run amongst a few other features are not in the Demo version.
« Reply #3 on: July 03, 2016, 12:08:29 AM »
Hi
i have a mach3 Usb(MK3-IV) and software Version R3.043.066(DEMO) on my Flame-cut cnc machine.
when select "normal-printer-port-operation" in first run plasma mode "REVERSE RUN" buttom is active but with select"NC-USB-pod-xhc-mach3-USB-motion card" doesn't work at all ...
m.rezaei@gitco.ir
thanks a lot
« Reply #4 on: July 03, 2016, 01:05:28 AM »
Hi
i have a mach3 Usb V4.3 (MK3-IV) and software Version R3.043.066(DEMO) on my Flame-cut cnc machine.
Is it possible that the software and the corresponding drive?
When installing drivers in the computer manager drive is unknown, but cutting is done. And only run reverse does not work.
If possible and appropriate driver software to send me.
please help me
m.rezaei@gitco.ir
thanks a lot
Offline dude1
  •  1,253 1,253
« Reply #5 on: July 03, 2016, 05:27:15 AM »
buy a licences
