Hello Guest it is October 21, 2026, 03:26:52 AM
Author Topic: Sure Servo drives with Mach  (Read 28237 times)
Re: Sure Servo drives with Mach
« Reply #10 on: April 15, 2008, 09:52:18 AM »
thank you for the diagram , now I just need to figure out motor tuning and setting the drive to the proper mode
« Reply #11 on: April 15, 2008, 11:43:37 AM »
back on the subject of using the sure servo drive with mach , is the 5v common shown in the diagram +5v or -5v . My break out board has a jumper to choose the common terminals as - or + ,I am sure this is a simple thing I should know but I am a machinist and my knowledge of electronics is very limited
« Reply #12 on: April 15, 2008, 03:16:34 PM »
Usually the Common is the Neg (-)
HTH,
Sid
« Reply #13 on: April 15, 2008, 04:54:12 PM »
It was done to the +5 side..
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #14 on: April 16, 2008, 09:28:41 AM »
Ooops- Sorry about that.  Thanks for the correction Brian!
Sid
