Hello Guest it is October 24, 2026, 10:47:09 AM
Author Topic: limit on g code of 49 lines?  (Read 12504 times)
« on: April 09, 2008, 09:35:00 PM »
Hey all. I'm in the process of finishing my first router and I have been playing around with Mach 3 and Lazy Cam. So far after trying many options that are available I think that Mach 3 is by far the easiest to use. At least for a newbie like me.
I tried to search for the answer to my question but couldn't find it. I can only post 49 lines of code in Mach 3. Is that normal before licensing or am I doing something wrong? I was under the impression that there was a 500 line limit. Kind of hard to evaluate it with only 49 lines available :)
I tried several of my drawings but all only result in 49 lines of code (full drawing in Lazy Cam though).
Thanks so much for your help.
Ryan
scottn
Re: limit on g code of 49 lines?
« Reply #1 on: April 09, 2008, 10:02:59 PM »
Hi Ryan,
Without either a Mach or a LazyCam license, LazyCam will only generate 50 lines of Gcode... With a LazyCam license (but without a Mach license), you would be restricted to the normal 500 lines...  ;)
scott
« Reply #2 on: April 10, 2008, 08:34:35 AM »
Thanks scottn. Just wanted to make sure there wasn't something else wrong. License it is then. 8)
Ryan
