Hello Guest it is November 21, 2026, 10:17:14 PM
Author Topic: Mach2 works fine but...  (Read 47619 times)
Netjams
« on: May 12, 2006, 07:38:53 PM »
Mach3 won't with all the same port settings.
It looks like it works but it's not getting to the port  :-\
I'm running..
P4 2.8 gig
XP Home
Any ideas?
Re: Mach2 works fine but...
« Reply #1 on: May 12, 2006, 08:02:38 PM »
i had the same problems with my lathe mr Barker helped me but could not get the spindle to turn then the maker of my lathe came to my home and tried a combination of input and output changes and got my lathe started with all feeds and spindle running like in mach2 (thanks again steeve) .if you wish i can send you the xml file for you lathe .
Netjams
« Reply #2 on: May 12, 2006, 08:11:00 PM »
I'm not sure the XML for your machine would help me out, as I'm running a home built router table with Geko 201 drives connected to a parellel port on my computer.
I have tried everything.. and Mach3 just wont talk to the port or port(s) for that matter. I used a port monitor and can see Mach2 changing status but Mach3 wont change any of them except if I force all pins high Mach3 will set them all low on startup but that is as much port activity as I can get out of it.
I'm sure it must be something simple that i'm missing in the program  :-\
Netjams
« Reply #3 on: May 12, 2006, 08:12:52 PM »
Oh and this is a purchased copy not the demo version, so that can't be an issue.
« Reply #4 on: May 12, 2006, 08:13:44 PM »
Could you pleawse post your XML and I will have a look at it..
www.newfangledsolutions.com
www.machsupport.com
Netjams
« Reply #5 on: May 12, 2006, 08:25:31 PM »
The Mach3mill.xml ? That is the one I have setup.
That is a huge file ?
ok here it is on my server,,
http://67.11.148.170/mach3mill.xml
« Reply #6 on: May 12, 2006, 08:37:24 PM »
Try this one..
www.machsupport.com
Netjams
« Reply #7 on: May 12, 2006, 08:55:10 PM »
No that did the same thing Brian.
I was looking in the XML and it shows all 0's for all the output ports.. Hmmmm.
I'm a fair programmer, with a hint I can play around and find it... But I'm sure others may have the same problem.
Netjams
« Reply #8 on: May 12, 2006, 09:15:38 PM »
I started a new profile with default settings and set up pins, hot keys and port to keep it clean.
http://67.11.148.170/router.xml
Looking at it (the XML).. it looks like all the ports, pins exec.. are set correct.
« Reply #9 on: May 12, 2006, 09:17:17 PM »
Still looking
 ;D
www.machsupport.com
