Hello Guest it is November 01, 2026, 12:18:18 PM
Author Topic: Lazy Cam 2  (Read 34268 times)
Re: Lazy Cam 2
« Reply #10 on: June 25, 2006, 02:14:32 AM »
Hi Brian,
I have downloaded Version 1.90.052 from Arts page and i have the same problem with the included LazyCam 2.53.
Maybe Art forget to update LazyCam?
Regards
Christer
Re: Lazy Cam 2
« Reply #11 on: June 25, 2006, 06:40:08 AM »
I just sent the code to Art so he is up to date now :) I will post here when it is updated.
sorry about that
Brian
www.newfangledsolutions.com
www.machsupport.com
Re: Lazy Cam 2
« Reply #12 on: June 25, 2006, 06:57:14 AM »
Hi Brian,
Thanks for the update  :)
Christer
Re: Lazy Cam 2
« Reply #13 on: June 25, 2006, 08:00:54 AM »
It is all updated and is part of .52 release of Mach3 :)
www.machsupport.com
Re: Lazy Cam 2
« Reply #14 on: June 25, 2006, 08:20:21 AM »
Hi Brian,
Downloaded and installed, LazyCam version is 2.54.
Loaded jpg image into LazyCam and the Raster XY and i get a "Bad character on line nuber #9"
It seems lika a "N55" is inserted, I edit it manual and then it seems to work fine,
Thanks Brian
Christer
N5 (File  )
N10 (File Posted in Mill Mode)
N15 (Sunday, June 25, 2006)
N20 G90 G80 G40 G91.1
N25 G0 Z1.0000
N30    X0.0000 Y0.0000
N35 M3 S100
N40    Z0.1000
N45    Z1.0000
N50 N55 M3 S100
N60    Z0.1000
N65 G1 X0.7000 Z-0.4000  F100.00
N70    X1.4000
N75    X2.1000
Re: Lazy Cam 2
« Reply #15 on: June 25, 2006, 08:23:40 AM »
I will Get this fixed tonight :)
Thank you
Brian
www.machsupport.com
Re: Lazy Cam 2
« Reply #16 on: June 25, 2006, 10:31:43 AM »
Should be fixed :)
Thank you
Brian
« Last Edit: June 25, 2006, 11:11:29 AM by Brian Barker »
www.machsupport.com
Re: Lazy Cam 2
« Reply #17 on: June 25, 2006, 10:41:56 AM »
Thank you Brian, :)
I wounder if you could consider to make the raster angle selectable in feature versions?
It seems like a angle of 30 degrees or so make the picture better looking (see http://www.vectric.com/WebSite/Vectric/pvc/pvc_index.htm)
Keep up the great work  :)
Christer
Re: Lazy Cam 2
« Reply #18 on: June 25, 2006, 11:12:05 AM »
I can look into it ...
www.machsupport.com
