Hello Guest it is November 01, 2026, 10:06:40 AM
Author Topic: Lazy Cam 2  (Read 34248 times)
Lazy Cam 2
« on: May 12, 2006, 06:18:54 AM »
Hi Brian,
I have some trouble with Lazycam 2.0 and MachIV 1.90.036.
When i import an image and make an raster image conversation, and post to g-code im not getting any Z-values.
It is working fine in MachIV 1.90.028.exe release, do i miss something or is it a bug?
Christer
Re: Lazy Cam 2
« Reply #1 on: May 12, 2006, 10:45:04 AM »
I think it is a bug :( I will hav to look at the output class.
Thank you
Brian
www.newfangledsolutions.com
www.machsupport.com
Re: Lazy Cam 2
« Reply #2 on: May 12, 2006, 11:22:56 AM »
Ok, thank you  :)
Christer
Re: Lazy Cam 2
« Reply #3 on: June 10, 2006, 09:38:15 AM »
Hi Brian,
Any progress on this problem, still miss the Z-value when i try Image to Raster function?
Best regards
Christer
Re: Lazy Cam 2
« Reply #4 on: June 11, 2006, 08:40:48 AM »
It is getting worked on today, sorry for not getting to it sooner
www.machsupport.com
Re: Lazy Cam 2
« Reply #5 on: June 11, 2006, 09:06:48 AM »
Hi Brian,
No problem, just want to check if i missed some update.
Christer
Re: Lazy Cam 2
« Reply #6 on: June 12, 2006, 06:53:45 PM »
I found the problem and I have fixed it :)
I have a few more things that I am working on so it is going to be a few days till the release is ready..
Just wanted to update you  ;D
Brian
www.machsupport.com
Re: Lazy Cam 2
« Reply #7 on: June 13, 2006, 02:17:51 PM »
Hi Brian,
Ok fine, thanks for your update.
Christer
Re: Lazy Cam 2
« Reply #8 on: June 24, 2006, 12:33:18 PM »
Hi Brian,
Just want to check when you think the new version will be out?
Have some wood engraving that i have to do. :)
Regards
Christer
Re: Lazy Cam 2
« Reply #9 on: June 24, 2006, 04:10:16 PM »
I think it is out now...
www.machsupport.com
