Hello Guest it is November 13, 2026, 09:34:28 AM
Author Topic: my first retrofit with mach3, please help  (Read 19351 times)
« on: May 11, 2006, 04:36:59 PM »
New to the forum and retrofitting.
I have Dyna 2800 with control I can’t handle; downloaded demo version of Mach 3 and it looks much friendlier than Dyna original.
Watched few times videos and read as much as I could, but don’t know what is my next step.
I have a wiring diagram for the machine, and for example on X driver board there are contacts DIR and STEP. Do I just connect them to corresponding pins on printer port of the PC or I need to install something in between?
Re: my first retrofit with mach3, please help
« Reply #1 on: May 11, 2006, 08:25:15 PM »
I did that in the past but the best way to go is to put gecko drives in the mill...
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: May 12, 2006, 12:13:48 PM »
Thank you,
Do gecko drives completely substitute Dyna built in driver boards or they are inserted in between? Which gecko model can you recommend and where can I buy those in the UK?
« Reply #3 on: May 12, 2006, 01:27:09 PM »
Just spoke to very helpfull technical support at gecko drives and got answers I needed.
Another qestion is about MACH3. When the milling machine homed, steppers are cut off by limit switches, what cuts steppers off when they reach opposite to limit swithches direction?
« Reply #4 on: May 12, 2006, 03:52:27 PM »
use the limit switches to home the mill and the softlimits will do the rest :)
www.machsupport.com
