Hello Guest it is November 13, 2026, 09:37:08 AM
Author Topic: siemens analog signal question  (Read 11662 times)
« on: March 23, 2008, 03:20:25 PM »
Does anybody know what the (VDI) standard is. I'm still trying to start a plan to upgrade my simodrive.I have found out its a +- 10 volt speed command. conforming to VDI  I need to know if i'm going to run into some wierd incompatibility  Thanks Al
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: siemens analog signal question
« Reply #1 on: March 24, 2008, 04:11:27 PM »
Hi, Asparaguy
You need a Step/Dir to 10 + - Volt Board, Hears a tester you can make.
Zero the volts before hooking it up to your servos + - leads, It will let you test them, Disconnect batteries when not being used.
Your "Step/Dir to 10 + - Volt Board" will need an Encoder input, From your servo amp or a separate Encoder.
Hope this Helps, Chip
« Last Edit: March 24, 2008, 04:14:15 PM by Chip »
