Mach Discussion => General Mach Discussion => Topic started by: asparaguy on March 23, 2008, 04:20:25 PM
Does anybody know what the (VDI) standard is. I'm still trying to start a plan to upgrade my simodrive.I have found out its a +- 10 volt speed command. conforming to VDI I need to know if i'm going to run into some wierd incompatibility Thanks Al
Hi, Asparaguy
You need a Step/Dir to 10 + - Volt Board, Hears a tester you can make.
Zero the volts before hooking it up to your servos + - leads, It will let you test them, Disconnect batteries when not being used.
Your "Step/Dir to 10 + - Volt Board" will need an Encoder input, From your servo amp or a separate Encoder.
Hope this Helps, Chip
