Hello Guest it is November 13, 2026, 12:16:22 PM
Author Topic: Always in the Slow Jog Mode  (Read 43930 times)
Re: Always in the Slow Jog Mode
« Reply #20 on: March 25, 2008, 06:29:04 PM »
Took your advice and changed the Motor Outputs to “A” and the input signals to A also.
See screen shots below.
Moved the jumper from Z on the BOB to the A position and the other end to the Z driver.
X and Y are working normally.  Z will not move + or -.
Checked the Dir voltage and both + and - were 0.
Connected the jumper from A on the BOB to the Y driver.
The Y stepper will move + and -.
Could not measure voltage cables in way.
Connected the jumper from the Y on the BOB to the Z driver.
The Z stepper will not move.
Looks like the Z driver card is not operating.
Replaced jumpers back to Y-Y   and A-Z
Took the Y cable connection to stepper and put it on Z stepper.  Z stepper will go + and – when going through the Y drive card.
Nothing is wrong with the Z stepper.
Could it still be Mach3?
I'll send PM with phone no.
Mr. Chips
Retired 3M'r
