Hello Guest it is November 13, 2026, 12:07:46 PM
Author Topic: Shut down Windows services, which ones?  (Read 27793 times)
« on: March 22, 2008, 08:03:13 PM »
There used to be a list of Windows Services that could be shut down/disabled that would help Mach, is that list around anymore?  The optimization.txt file that I've seen lately doesn't have that.  Did shutting down the services end up not helping?
Monte
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: Shut down Windows services, which ones?
« Reply #1 on: March 23, 2008, 05:55:39 AM »
I dont know anything about the list, but yes.
In theory, Windows can (and does) run many programs simultaneously. Many of these run in the background and you are unaware of them. They do, however, take up processor time, since the processor can only process one instruction at once (discount dual procesors at the moment).
These processes can be seen (as you probably know) by pressing Alt,Ctrl and Delete. Selecting processes will show what is actively loaded on your system. Many of these - especially those marked "User" - can be shut down, and, in theory, will leave more processor time free to run Mach 3.
I must admit I would like to get hold of an "essential list" - in other words those programs Windows needs to function - and then I could shut the rest - particularly on my workshop computer.
« Reply #2 on: March 23, 2008, 07:25:18 AM »
hi,
Try this optimization, it worked for me, I cant remember where on the forum i found it but credit to whom ever.
I have seen such a list I will look for it
goodluck Friedrich
(This file has been updated to exclude the least effective items)
NOTE: ***** Before doing ANY optimising, run MAch3 first, odds are you dont need to optimise.
      ***** and before optimising, use msconfig to shut off all Startup Items, then reboot.
            Killing stratup Items fixed 90% of computers having any troubel with MAch3.
            Optimising should NEVER be done priot to knowing a problem exists.
Windows XP Professional System Optimization Guide:
0. Install Windows in Standard PC Mode
1. When you see the installation tell you to press F6 (Third Party
SCSI or RAID Drivers) press F5 instead.
2. You will see Press F2 for Automated System Recovery, (DONT press
F2).
3. Right after that you will see a list.
4. Press the UP arrow key to highlight Standard PC.
When installing, make SURE you install all of the most recent drivers
for your
Hardware. This is vital!
6. Disable Automatic Updates
1. Right Click My Computer and select Properties
2. Click Automatic Updates tab.
3. Uncheck Keep my computer updated..
4. Click OK.
7. Disable Remote Assistance
2. Click Remote tab.
3. Uncheck "Allow Remote Assistance Invitations.".
4. Click OK.
9. Set Computer to Standard PC NOT ACPI PC
NOTE: This is only necessary if you wish to remove ACPI AFTER install.
If you followed step 0, you don't need to do this.
2. Click Hardware tab.
3. Click Device Manager Button in the middle.
4. Double click "Computer".
5. Right click on Standard ACPI PC and choose Update Driver.
6. Choose "Install the software from a Specific Location (Advanced)"
7. Click Next.
8. Choose "Don't search. I will choose driver to install."
9. Click Next.
10. Choose "Standard PC" from the listing.
11. Click Next.
12. Click OK.
11. Disable Startup Items in Registry
1. Click Start button.
2. Click Run.
3. Type MSCONFIG and press [ENTER].
4. Click Startup tab.
5. Uncheck everything
6. Click OK.
7. Exit MSCONFIG.
12. Disable Startup Program Group Items in Start Menu
1. Right click Start button and choose Open.
2. Double click Programs.
3. Double click Startup.
4. Delete anything you think you don't need.
5. Close window.
16. Set Windows Theme to CLASSIC
1. Right-click on your desktop, and then click Properties.
2. Click on Themes tab
3. Set Themes to Windows Classic
4. Hit OK
17. Disable Indexing on all NTFS drives
1. Double click My Computer.
2. Right click on hard drive and choose Properties.
3. On bottom, uncheck "Allow Indexing Service to index this file for
faster searching". 4. Hit OK.
18. Run diskperf -n (Turns off disk performance monitor)
1. Click the Start Button.
2. Click Run.
3. Type DISKPERF -N and press [ENTER].
20. Disable MSN Messenger
1. Double click on the Messenger icon in the system tray to open it.
2. Skip thru the internet and sign up stuff, just cancel it.
3. When Messenger loads go to Tools -> Options then Preferences.
4. Uncheck 'Run this program when windows starts'
21. Disable Power Management
2. Click on the Screen Saver tab.
3. Set Screensaver to None.
4. Press the Power button near the bottom.
5. Set all options to NEVER shut down automatically!
22. Disable Wallpaper
2. Click on the Desktop tab.
3. Where it says Background, scroll all the way up and choose None.
4. Click OK.
23. Disable System Sounds
1. Click Start Button.
2. Click Settings.
3. Click Control Panel
4. Double click Sounds and Audio Devices.
5. Click Sounds tab.
6. For Sound Scheme, choose "No Sounds".
7. Click OK.
25. Install Programs
Do not install any programs you will not use. Only install programs
that you DEPEND on for what you do on your computer. Keeping things
lean and mean will keep your system fast and stable.
26. Maintain Hard disk
1. Double click on My Computer.
2. Right click on Hard Disk and choose Properties.
3. Click Tools tab.
4. For Error Checking click Check Now. Do before Defrag!
5. Click Defragment Now, AFTER Error Checking completes.
6. Click OK.
27. Disable Ballon tips
1. Click Start - Run and type Regedit followed by enter
2. Navigate to
   Hkey_Current_User\Software|Microsoft\Windows\CurrentVersion\Explorer\Advanced
3. Click Edit - New - Dword value and create a new Dword called EnableBallonTips - Enter
   Double click on it and set value date field to 0 (Zero) typing 1 (one) will restore it
28. How to change the default file naming from upper case to lower case
2. Navigate to
3. Double click on Dword DontPrettyPath and change value to 1 (one)
« Reply #3 on: March 23, 2008, 11:18:34 AM »
I've found there are several lists on the WWW to be found.  I've gone through a couple, see what happens.
Monte
« Reply #4 on: March 23, 2008, 01:06:42 PM »
The optimisation list is on the main downloads page.
« Reply #5 on: March 23, 2008, 01:28:30 PM »
Thanks, I have that one.  There used to be one listing Windows Services that could be shut down.  I found some lists on the WWW that describe what services can be shut down.
Monte
