Hello Guest it is November 13, 2026, 09:35:44 AM
Author Topic: missing steps???!  (Read 12755 times)
missing steps???!
« on: March 18, 2008, 11:15:39 AM »
I don't know if this is the right term, but I am just about done with an installation (retrofit of a Shizouka cnc knee mill using the original steppers), and sometimes when I run a rapid using mdi mode, my x axis motor just 'whines' -makes a higher pitched noise than usual and just sits there.  I have 14 thou of backlash which I know I need to fix.  Usually, it doesn't have any problem, and it is the only axis for which I have programmed backlash.  The Y axis is set to the same motor tuning parameters.
I am using Gecko 203V's.
Any Ideas?
Thanks.
Bill
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: missing steps???!
« Reply #1 on: March 18, 2008, 03:20:54 PM »
Hi, Bill
Reduce the Velocity and Acceleration some for the X axis, Velocity is used as your top Feed-rate Rapid G00 moves.
Have you checked the Gecko's manual for jumpers and adjustment's for large steppers.
Hope this Helps, Chip
« Reply #2 on: March 18, 2008, 10:27:00 PM »
I'll give it a try.
Bill
