Hello Guest it is November 18, 2026, 09:55:34 AM
Author Topic: retrofiting dyna 2800  (Read 24327 times)
« on: May 09, 2006, 03:45:20 PM »
I got dyna 2800 cheaply, would like to retrofit it to use with mach software. Would appreciate advice from anyone who done it with Dina.
Thank you
ynneb
Re: retrofiting dyna 2800
« Reply #1 on: May 14, 2006, 06:00:21 PM »
I am not familiar with the Dina setup, however there isnt many machines you cant convert.
Is it currently a stepper setup?
« Reply #2 on: May 15, 2006, 03:57:38 AM »
It is stepper setup and motors run very, very good from original contrall. I have started conversion yesterday and can’t get motors turning in whatever I tried.
I think I run through all possible combination of data on Mach3, table moves left and right (I started with X axis first). It doesn’t sound correct whatever I do. I still have old control working and I can hook it back just to compare.
I don’t use Geckodrives, just feed DIR and STEP on original driver board for X axes from corresponding printer port output.
From Dyna 2800 original control motors works beautifully, the movement of every axis is very smooth and dynamic.
It looks like I have to probably buy Geckodrives G201, may be Dyna original driver boards don’t get on well with Mach3 signals from parallel port.
« Reply #3 on: May 15, 2006, 09:02:14 AM »
Use the Sherline mode and they will run great! it is on the ports and pins page...
www.newfangledsolutions.com
www.machsupport.com
« Reply #4 on: May 15, 2006, 11:45:43 AM »
Brian, I owe you
It runs great now
« Reply #5 on: May 15, 2006, 12:06:09 PM »
Sweet  ;D  !!!!
www.machsupport.com
« Reply #6 on: May 16, 2006, 03:21:51 PM »
Now most of the wireing done and machine works well with Mach3.
It moves and cuts smoothly in linear mode, cut rectanguler pocket using wizards librery
However when it start cutting arcs and circles the axeses straggling, motors make not healthy noise, what can it change to get it right?
« Reply #7 on: May 17, 2006, 08:58:34 PM »
I think what you are hearing is the steppers at slow speed.. try jogging the mill at low speeds.
www.machsupport.com
