Hello
Guest
it is
November 13, 2026, 11:47:35 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Nested Comments
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Nested Comments (Read 27118 times)
ronald4418
46
Nested Comments
on:
March 17, 2008, 06:07:06 AM »
Is there a way to get Mach3 to work with Nested Comments in a g-code file? I have found a great little program for creating gears and it lists nested comments in the .nc file that it creates. Mach3 sees these comments as errors. Therefore I have to spend a considerable amount of time deleting these comments. I've enclosed an attachment of an 8 tooth clock pinion as an example.
Overloaded
4,923
Re: Nested Comments
Reply #1 on:
March 17, 2008, 07:19:20 AM »
I believe Mach needs ( and ) around a comment instead of a * .
RC
It may possibly be changed in the Post Processor or choose another PP ? Not sure though.
Last Edit: March 17, 2008, 08:33:06 AM by Overloaded
ronald4418
46
Re: Nested Comments
Reply #2 on:
March 17, 2008, 02:53:13 PM »
The program in question provides no option to change or modify the post processor. I was hoping that there was an option in Mach3 to allow nested comments.
Chip
2,055
Gainesville Florida USA
Re: Nested Comments
Reply #3 on:
March 17, 2008, 04:31:18 PM »
So what' the name of the, "great little program for creating gears"
And you can use ; also.
Thanks, Chip
Chip
2,055
Re: Nested Comments
Reply #4 on:
March 17, 2008, 04:57:17 PM »
Hi, Ronald4418
Use the find & replace feature in Notepad edit in mach3.
Thanks, Chip
Overloaded
4,923
Re: Nested Comments
Reply #5 on:
March 17, 2008, 05:19:01 PM »
EXCELLENT CHIP,
THAT is very handy.
Now I can say that I learned something today.
RC
Chip
2,055
Re: Nested Comments
Reply #6 on:
March 17, 2008, 05:52:54 PM »
Hi, RC
Now if we could just (only) keep it all sorted.
The gear program has some further things/issues to sort out, I think.
Thanks, Chip
Overloaded
4,923
Re: Nested Comments
Reply #7 on:
March 17, 2008, 06:43:24 PM »
Chip,
Yes, I noticed that. Looks like several "spring" cuts.
RC
vmax549
Re: Nested Comments
Reply #8 on:
March 17, 2008, 08:42:30 PM »
Hey Chip can you make a gcode file renumber all the lines in proper order(;-)
Chip
2,055
Re: Nested Comments
Reply #9 on:
March 17, 2008, 09:28:41 PM »
Hi, TP'(;-)
Hears a Link to nclink_free.exe By OneCnc, It has a g-code file renumber in it.
http://www.hscnc.com.au/toc.htm
Hope this Helps, Chip
Print
Pages:
1
2
Go Up
« previous
next »
