Hello Guest it is August 28, 2026, 03:30:54 AM
Author Topic: Eagle on a Globe  (Read 19896 times)
Eagle on a Globe
« on: March 12, 2008, 02:03:27 PM »
Made this Eagle on a globe from a file found on cnczone.com
Its made out of 3/8" plywood, and cut with a 1/4" ecarbide 2 flute straight cutter
Thanx jimini ( I believe)
Best reg
Cory
« Last Edit: March 12, 2008, 02:06:18 PM by corydoras »
Offline Glenn
  •  129 129
Re: Eagle on a Globe
« Reply #1 on: March 15, 2008, 07:25:05 PM »
Great job Cory :)
   How tight of a fit did you get when assembling all the pieces? how many parts all together?
 What is the eagle's wingspan?
 Awesome!
 Glenn
Don't assume anything.....it'll make a Manager out of U and Me!
« Reply #2 on: March 17, 2008, 07:19:53 AM »
Thanx Glenn
The cuts where made at 8.95 mm and the plywood is about 9.08 mm, ao the whole thing was knocked together with a leftover oak stick.
It is extremely tight fit, but it is very sturdy dry fittet.
In fact it was a little to tight as you can see from the picture.
I could not get the globe tight enough together so thet it would fit the slots in the stand.
I think it is completed out of somwhere between 60 and 70 pieces
I can send you the dxf file if you are interested
Best reg
Cory
« Reply #3 on: March 17, 2008, 05:31:54 PM »
Hello Cory,
I would like the dxf also....if you dont mind.
I like eagles.
RC
« Reply #4 on: March 17, 2008, 09:02:13 PM »
Great job Corey, keep up the good work. I'd like the dxf as well.
« Reply #5 on: March 18, 2008, 08:30:57 AM »
Here is the dxf file of the eagle, just scale it to suit your material thickness
Enjoy
Cory
« Reply #6 on: March 18, 2008, 09:34:56 AM »
Thanks Cory,
RC
« Reply #7 on: March 30, 2008, 08:09:18 PM »
Beautiful job, I really wish I had room for a cnc router (I have a taig benchtop)!
« Reply #8 on: April 08, 2008, 10:19:19 AM »
Hi Cory
Thanks for the Dxf.
I have made the bird of 3mm triplex, in Lazycam made an offset to cut with A 1mm cutter.
Fits OK, nice bird, thanks again.
Greetings:
Willem
