Hello
Guest
it is
November 18, 2026, 01:50:20 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Change "TAB" Hotkey
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Change "TAB" Hotkey (Read 30580 times)
JonnyD
16
Change "TAB" Hotkey
on:
March 02, 2008, 04:09:39 PM »
I'm currently running Mach3 with a touchscreen and wireless keypad. Is there a way to change the default jog key (TAB) to the keypad decimal point (.)?
Logged
Carnoustie, Scotland
Re: Change "TAB" Hotkey
Reply #1 on:
March 02, 2008, 04:27:30 PM »
You should be able to make a new screen button and have the button set as OEM Code 50, then you can asign a hotkey for that.
Will go try it out but it should work
Logged
Reply #2 on:
March 02, 2008, 04:32:01 PM »
OK just tried it and it doesnt work
Just opens a blank screen, maybe Brian will have an answer.
Logged
Chip
2,055
Gainesville Florida USA
Reply #3 on:
March 02, 2008, 04:38:42 PM »
Hi, Hood
Make the button Oem 323 will do it.
Thanks, Chip
Logged
Reply #4 on:
March 02, 2008, 04:47:26 PM »
ok chip, thanks
EDIT
Yep works like a charm
Last Edit: March 02, 2008, 04:52:44 PM by Hood
Logged
JonnyD
16
Reply #5 on:
March 02, 2008, 05:01:11 PM »
Newbie here,
How do I make an OEM button
Logged
Reply #6 on:
March 02, 2008, 05:08:37 PM »
You use screen4, it may be in your Mach folder, if not its available on the downloads page. Its a great wee addition, lets you alter the standard screenset or even make up your own like many of us have done, see here
http://www.artsoftcontrols.com/screens.htm
I have added the button to this screen, its placed offscreen so you wont see it but it should work fine when you press the . key
Download the attached screenset and save it in your Mach 3 folder, then when you open Mach go to the View menu the load screen and browse to Mach3 folder and choose it.
Logged
JonnyD
16
Reply #7 on:
March 06, 2008, 04:35:10 PM »
Hood, works like a charm.
I didn't even know screen4 exist. What a cool feature.
I tried making my own button with 0 width and 0 height offscreen. It seems to work but the overall Mach screen got reduced depending on where I place my button.
Logged
Chip
2,055
Reply #8 on:
March 06, 2008, 04:59:18 PM »
Hi, JonnyD
Why not put it on the screen also, and set it for all screens ?
Thanks, Chip
Logged
Reply #9 on:
March 06, 2008, 05:13:20 PM »
If you dont want to have the button visible you could use an image button in screen4 but just dont asign an image to it, it will become an invisible button. I have one like that on my screen for clearing the ticker message
Logged
Print
Pages:
1
2
Go Up
« previous
next »
