Hello Guest it is September 27, 2026, 12:37:32 PM
Author Topic: Drawing an Airfoil for LCam  (Read 17098 times)
« on: February 26, 2008, 10:17:44 AM »
Hey All,
Can someone get me started with 'how to draw an airfoil' in AC Lt 98 that will work in LCam ?
I can find the NACA coordinates for the points but then I'm stuck. I'm relatively sure that I'm not to simply connect the dots......?
RC
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Drawing an Airfoil for LCam
« Reply #1 on: February 26, 2008, 10:35:37 AM »
I have never used LT but on my system I do a "create spline from points" command and it fits the best curve it can between the points.  Then I do a convert spline to lines and arcs.
Graham.
« Reply #2 on: February 26, 2008, 03:18:48 PM »
LT doesn't seem to have those functions.....I'll dig a little deeper later on.
Thanks Graham,
RC
« Reply #3 on: February 27, 2008, 07:15:13 AM »
Graham,
Is the "arc-fit polyline" and "spline-fit polyline" = to what you are referring to ?
If I post a spline .dwg, would you convert it for me ?
RC
  •  2,785 2,785
« Reply #4 on: February 27, 2008, 07:40:52 AM »
spline-fit polyline sound very near. I will try to convert it for you.
Graham.
« Reply #5 on: February 28, 2008, 09:07:19 AM »
Thanks Graham,
A net search revealed a dwg. file for every airfoil ever documented...No need to draw them.
RC
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #6 on: February 28, 2008, 10:57:12 PM »
Hi, RC
Would you post the link for the airfoils.
Is this the one ?  http://isoar.ca/~andrewm/rc/airfoils/index.html
Thanks, Chip
Edit: Thanks, RC, Chip
« Last Edit: March 02, 2008, 01:26:43 PM by Chip »
« Reply #7 on: February 29, 2008, 05:41:38 AM »
Hello Chip,
The one you have there is good. I'll keep it too.
The one that I found is: http://www.davincitechnologies.com/AirfoilOptimizerStdAirfoils.htm
RC
And here are the tables of coordinates: http://www.pdas.com/avd.htm
« Last Edit: February 29, 2008, 05:43:48 AM by Overloaded »
