Hello
Guest
it is
November 19, 2026, 03:58:34 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
Drawing an Airfoil for LCam
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Drawing an Airfoil for LCam (Read 17470 times)
Overloaded
4,923
on:
February 26, 2008, 10:17:44 AM »
Hey All,
Can someone get me started with 'how to draw an airfoil' in AC Lt 98 that will work in LCam ?
I can find the NACA coordinates for the points but then I'm stuck. I'm relatively sure that I'm not to simply connect the dots......?
RC
Graham Waterworth
2,785
Yorkshire Dales, England
Re: Drawing an Airfoil for LCam
Reply #1 on:
February 26, 2008, 10:35:37 AM »
I have never used LT but on my system I do a "create spline from points" command and it fits the best curve it can between the points. Then I do a convert spline to lines and arcs.
Graham.
Overloaded
4,923
Reply #2 on:
February 26, 2008, 03:18:48 PM »
LT doesn't seem to have those functions.....I'll dig a little deeper later on.
Thanks Graham,
RC
Overloaded
4,923
Reply #3 on:
February 27, 2008, 07:15:13 AM »
Graham,
Is the "arc-fit polyline" and "spline-fit polyline" = to what you are referring to ?
If I post a spline .dwg, would you convert it for me ?
RC
Graham Waterworth
2,785
Reply #4 on:
February 27, 2008, 07:40:52 AM »
spline-fit polyline sound very near. I will try to convert it for you.
Graham.
Overloaded
4,923
Reply #5 on:
February 28, 2008, 09:07:19 AM »
Thanks Graham,
A net search revealed a dwg. file for every airfoil ever documented...No need to draw them.
RC
Chip
2,055
Gainesville Florida USA
Reply #6 on:
February 28, 2008, 10:57:12 PM »
Hi, RC
Would you post the link for the airfoils.
Is this the one ?
http://isoar.ca/~andrewm/rc/airfoils/index.html
Thanks, Chip
Edit: Thanks, RC, Chip
Last Edit: March 02, 2008, 01:26:43 PM by Chip
Overloaded
4,923
Reply #7 on:
February 29, 2008, 05:41:38 AM »
Hello Chip,
The one you have there is good. I'll keep it too.
The one that I found is:
http://www.davincitechnologies.com/AirfoilOptimizerStdAirfoils.htm
RC
And here are the tables of coordinates:
http://www.pdas.com/avd.htm
Last Edit: February 29, 2008, 05:43:48 AM by Overloaded
Print
Pages:
1
Go Up
« previous
next »
