Hello Guest it is October 21, 2026, 05:55:21 PM
Author Topic: Looking for pinout on litton encoder.  (Read 17058 times)
« on: February 25, 2008, 09:14:51 PM »
Hey everybody,
     Does anybody happen to know the pinout for a Litton encoder. I have attached a picture to help.
« Last Edit: February 26, 2008, 10:24:00 PM by Chaoticone »
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Looking for pinout on litton encoder.
« Reply #1 on: February 25, 2008, 11:27:21 PM »
Hi, Brett
If you could make it just a little bigger the whole wild world could see it.
If you'd clean it up a little it'll probably work one more time, (electrical contact cleaner).
Chip
Edit: Color code is probably, Blk Gnd, Red Pos, White A, Blu B, Grn Sig Gnd maybe Index is there a index ring on the disk ?
I'll give you a call tomorrow.
« Last Edit: February 26, 2008, 12:55:56 AM by Chip »
« Reply #2 on: February 26, 2008, 08:12:25 AM »
Thanks Chip,
     A q-tip and a spin revealed an index count.  :)
« Reply #3 on: February 26, 2008, 10:19:14 PM »
I got the encoder all figured out  :). Not certain which is A and B channel yet, but will know soon. A friend suggested I look up the data sheet for the chip and it cleared it all up. This is a great link to a wealth of info.   http://www.datasheetcatalog.com/datasheets_pdf/L/M/3/3/LM339N.shtml
Chip, as far as I know this is correct. Not certain which is A and B channel yet, but will know soon. Green is the index pulse.
« Last Edit: February 26, 2008, 10:22:02 PM by Chaoticone »
Offline Chip
  •  2,055 2,055
« Reply #4 on: February 26, 2008, 11:12:56 PM »
Hi, Brett
You'll no pretty quick if you have it backwards, Your Gecko will trip pretty quick after reset.
Chip
