Hello Guest it is November 22, 2026, 02:24:14 PM
Author Topic: How do I activate "allow block delete"  (Read 21086 times)
« on: May 03, 2006, 05:52:13 PM »
Where's the switch to activate "allow block delete"
Jim
Re: How do I activate "allow block delete"
« Reply #1 on: May 03, 2006, 08:11:13 PM »
the LED needs to be on to get it to work...
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: May 04, 2006, 12:58:03 PM »
How easy can it be. How could I have overlooked something so obvious. I've yet to check my machine though. No doubt the switch will be there.
« Reply #3 on: May 04, 2006, 05:52:42 PM »
no problem, I do the same thing  :o
www.machsupport.com
« Reply #4 on: May 06, 2006, 07:22:40 PM »
Ok, so what do you do with Block Delete?
« Reply #5 on: May 06, 2006, 07:30:16 PM »
If you are running parts that may need to have an extra pass to You can add the code with a "/" at the start of the block. As you can see in this example you could add a face pass...
G00 Z1.0
G00 X0.0 Y0.0
/G01 Z0.0 F30
/X5.0
/G00 Z1.00
/X0.0
G01 Z-.1 F30
www.machsupport.com
