Hello
Guest
it is
November 13, 2026, 09:37:43 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Feed Rate Errors
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Feed Rate Errors (Read 15904 times)
3FAB
Feed Rate Errors
on:
May 02, 2006, 06:13:35 PM »
Mach 2 will radius an angle cut when the feed rate is to high on our plasma cutter. How do I prevent this from happening without slowing the feed rate down? Does Mach 3 have this same problem?
Logged
Brian Barker
3,860
Re: Feed Rate Errors
Reply #1 on:
May 02, 2006, 07:06:34 PM »
That is the CV (G64) try putting it in Exact stop (G61)
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
