Hello
Guest
it is
November 13, 2026, 04:47:55 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Gcode fore changing pulley ratio or pulley #
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Gcode fore changing pulley ratio or pulley # (Read 16649 times)
milehigh51
13
on:
February 18, 2008, 03:58:21 PM »
Hi all:
Can some one help me out here? with gcode fore changing pulley ratio or pulley # . I see in turn the tool table has an entry for turret... but what is it for. Also in turm their is a DRO for loop. I run most of my programs as a sub programso the LXX is how many parts in the bar. if it kept track of how many loops I would know how long till it
runs out of stock.
Thanks Roy
Logged
Carnoustie, Scotland
Re: Gcode fore changing pulley ratio or pulley #
Reply #1 on:
February 19, 2008, 02:12:52 AM »
Not sure exactly what you are wanting regarding the pulley ratio/number.
I am presuming you are meaning Turret Angle, I think this will simply be so that you can define the angle of the rotation to get to that tool.
Logged
milehigh51
13
Reply #2 on:
February 19, 2008, 08:06:54 AM »
Hi hood
The pulley selection in config/spindle pulleys Their must be a way to select the choice you need in a macro or gcode.
for forgetful machinist!! tell me more bought the turret angle. I Always wandered what that was for.
thanks
Roy
Logged
vmax549
Reply #3 on:
February 19, 2008, 09:02:30 AM »
You can change the pulley select with a macro or Mcode in your program. You will have to create the macro and place it in the correct macro directory. You will have to have a macro for each pulley selection that you want to use.
Logged
Print
Pages:
1
Go Up
« previous
next »
