Hello Guest it is November 22, 2026, 08:41:02 AM
Author Topic: Can you set up 2 different machines with Mach3?  (Read 13498 times)
Offline Garyv
  •  103 103
« on: February 16, 2008, 09:49:27 PM »
I  have a mill running Mach3 now and I am going to building a router now as well and want to use the same drives and controllers, Is there a way to
save settings for different 2 machines in Mach3?
   So all I have to do is unplug motors and limits from one to the other without changing setups or anything?
GaryV
Offline Garyv
  •  103 103
Re: Can you set up 2 different machines with Mach3?
« Reply #1 on: February 16, 2008, 10:22:13 PM »
Not sure if I found it but do I set up a new profile when I start Mach3 under the Mach3 loader icon when I start Mach ?
GaryV
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: February 17, 2008, 03:04:20 AM »
That's the way to do it.
Graham.
